Set Resource Individuality Options
Sets options for remembering and reusing individual resource team members.
- Work Center - Work Center/Activity where resource is used
- Resource - Resource name
- Mode - Is this work center remembering (the first to use) the resource, or is it using a previously remembered resource. The options for mode are Remember or Use Remembered.
- Label - Label to store the individual resource information
VL SECTION: proc_Set_Resource_Individuality
Set Resource Individuality Options Activity 1 , Resource 1 , Remember , lbl_ResourceUsed
Set Resource Individuality Options Activity 2 , Resource 1 , Use Remembered , lbl_ResourceUsed
Referring to the example Visual Logic and image above, Activity 1 will Remember the resource that was used on the work item, and it will set Activity 2 to use the Remembered resource.
