View Objects of Type
The Object List Dialogs are lists of the objects that form the structure of your simulation simulation. View object by type is located on the data & rules tab.
You can view all object types at once or use the drop down menu options on the ribbon button to view objects of just one type at a time.
It will include all the invisible objects too.
To create a new object click the appropriate button on the tool bar and then click on the simulation window where you would like the object to appear.
This list can also be used to delete objects. You can select a number of objects in the list at one time (click on them with SHIFT or CONTROL pressed on the keyboard - just like in File-Manager) and then delete them all by clicking the DELETE button.
You can get to see the details of an object more quickly by simply clicking on it on the simulation window.
