Graphics
Use the Conveyor Graphics Dialog to configure the way each Conveyor is displayed.
Show
When checked the following settings show:
- Static Image - Show the image for the Conveyor
- Animated - Shows each Work Item as it moves along the Conveyor
- Animated with Visible Belt - This is the default setting, shows each Work Item as it moves along the Conveyor with a background image so the Conveyor can be seen when empty
- Graph - Shows a graph of the number of Work Items processed by the Conveyor over time
- Width - Change the display width of the conveyor belt if the 'Animated with Visible Belt' option is selected
- Colors - Change the color of the conveyor belt if the 'Animated with Visible Belt' option is selected or the graph if the 'Graph' option is selected
- Invisible - Hide the Conveyor image onscreen
- Count - Show the number of Work Items currently being worked on by the Conveyor
- Title - Show the name of the Conveyor. More on Object Titles
- Work Item - Show the image of the Work Item currently being processed
- Data Graphic - Show customized information beside the Work Center More on Data Graphics
- Image List - Change the image for the Conveyor depending on a variable value More on Image Lists
- Dogs on Fixed Pitch - These options set the graphical properties of Power and Free / Fixed Pitch Conveyors
Default
Save the current display settings as the default display settings for all new Conveyors created
