Connect Multiple Simulations
With Simul8 it's possible to have multiple simulations talking with one another, so what happens in one simulations effects what happens in another.
To do this you use the Exit Times to CSV feature to write the outputs of one simulation to a CSV file. Then you use the Arrivals from CSV file feature to read the outputs into another simulation.
Download the following two files to see this in action. Run simulation one first to generate the exit data, then run simulation two, this will pull the exits from simulation one as it's arrivals.
