Custom Menus
Simul8 allows you to create your own custom menus.
Select command menus from the Insert tab to create and configure a menu unique to your Simul8 simulation.
Click the name of the Custom Dialog you wish to add to this menu and add it to the 'Appears in menu' box.
Type a name for your new menu and check the INCLUDE COMMAND MENU check box.
Clicking the custom menu from the Home tab now runs the dialog for the user.
Hold down CONTROL when you click the menu item to directly enter the dialog editor for faster editing.
The Disable During Run option makes the Dialog “grayed out” and inaccessible during a run. If this option is not checked the user can access the menu, pausing Simul8 so that a minor change can be made through a user defined Dialog.
