Display
The following options are available from the Display tab in Preferences.
Keep Mouse in Window
Switch this preference option on to make windows automatically scroll (if the mouse starts to move outside the window) when you drag the mouse.
Remember that if this option is switched on, then you cannot drag between objects that are in different windows.
Default Images
Simul8 has sets of default icons that can be changed to suit the industry sector to be modeled.
Icons for each simulation object can be changed from the default set of Business icons to icons from the Call Center, Healthcare or Manufacturing industry.
This can be done through the Display tab in Preferences.
Once a new set of icons is selected, the Simulation Drawing Panel is automatically updated with alternative icons.
