Data & Rules Tab
Clock Properties
Set up the working hours of your simulation and the display of the clock.
More information
Calendar
Run your simulation against a calendar of dates.
More information
Shifts
Set up the shifts for your resources and Work Centers.
More information
Labels
See all the Labels in your simulation and create new ones.
More information
Distributions
See all the distributions in your simulation and create new ones.
More information
Create Distributions
Create your own custom distribution.
More information
Spreadsheets
A list of all the spreadsheets in your simulation.
More information
Information Store
The information store is a where all the global data items are stored. Global data items are items of data that can be used in your simulation to measure or control what is happening.
More information
Groups
Put simulation objects into and manage your groups.
More information
Resource Matrix
See where your resources are assigned in one central table.
More information
Scheduled Maintenance
Apply scheduled downtime to activities in your simulation.
More information
View Objects of Type
Lists of the objects that form the structure of your simulation simulation.
More information
Input Summary
A summary of all the objects and their properties in your simulation.
More information
Quick Build
More information
Jobs Matrix
Control the sequence of work via a matrix rather than routing arrows.
More information
Cycle Matrix
An alternative method to describe routing in your simulation, where you define each of the cycles of activity at your Work Centers.
More information
Links
View and change the routing between all your simulation objects.
More information
Overheads
Specify fixed costs and revenues that apply to your whole simulation.
More information
Excel Connections
Import data from Excel and export results using an easy connection wizard.
More information
