COM Example using Python
This example outlines how to use Python IDLE and COM to run a Simulation as well create a PDF report of the KPI results to provide to stakeholders.
Simul8 Python COM
The Simul8 Model in the image above is a factory model with a few activities needing several resources to function. In the Export Results section, the KPI results are set to export to a CSV file on end run. This allows us to export the results without triggering this manually within Simul8 when using COM to call the simulation.
Simul8 Python COM
Within the Python IDLE the simulation is connected as detailed here. It is then run using the commands below. *Note the first section may not be needed if Simul8 has been connected before and can be removed. This is what connects the library, more info found here.
Simul8 COM Python
An Event using the Event Handler was also scripted in to allow the KPIs to be previewed directly into the IDLE Shell. Here the Event handler is the overall Class with the Simulation Event function defined as “OnS8SimulationEndRun”. Within the function the “ResultsCount” command in the same Class of commands is utilised to print the results.
Simul8 COM Python
These are just some of the several commands available with Simul8 and COM with the full list available here.
The next section of the .py file is used to write a pdf file highlighting the KPIs of the run. When running this example on your own machine remember to connect the CSV within the export option of Simul8 to the correct section, this similarity will need to be done for the Simul8 file location and the read file section of the Python script.
*Note the packages needed in the script will need to be preinstalled for the script to function.
When run a Simul8 PDF will appear in the directory selected. It will also be called in the last section of the .py script. This will display results similar as the image below depending on the run time chosen.
Simul8 COM Python
Files used in example:
See also
