Call COM Event
COM (Component Object simulation) is a method of enabling communication between packages. COM is available only with Simul8 Professional.
Sends a string of text to a programming language, such as Microsoft Visual Basic, Microsoft Visual Basic for Applications, Borland Delphi, or any other COM enabled package.
Enter the text, in inverted commas, that will call the COM event.
Use this command to invoke a COM event. For example at the end of a simulation run or trial it may be desirable to send a command to run or continue a routine.
