Conveyor Properties
Read and Write Properties
The Conveyor properties that are editable through the Visual Logic Set Value editor are:
Accumulating
Toggles on and off the Allow Gaps check box.
Example:
Set Conveyor1.Accumulating = 1: checks the box
Set Conveyor1.Accumulating = 0: un-checks the box.
Allow Gaps
Example:
Set Conveyor1.Allow Gaps = 1: checks the box.
Set Conveyor1.Allow Gaps = 0: un-checks the box.
Efficiency Repair Time
Sets the Repair time in Detailed Efficiency to a fixed value.
Example:
Set Conveyor1.Efficiency Repair Time = 5 (can also be a Global Data Item or Distribution)
Efficiency Work Time
Sets the Time Between Breakdowns in Detail Efficiency to a fixed value
Example:
Set Conveyor1.Efficiency Work Time = 100 (can also be a Global Data Item or Distribution)
Ignore Blocked Routes
Sets the Conveyor's Routing Out Property check box for. Ignore Blocked Routes to either Checked or not Checked.
Example:
Set Conveyor1.Ignore Blocked Routes = 1: checks the box
Set Conveyor1.Ignore Blocked Routes = 0: un-checks the box
Sets the image used for the Conveyor to any image located in the Graphics, Images menu option.
Example:
Set Conveyor1.Image = "BlueB": where BlueB exists as an image. Note the Inverted Commas around the name of the image
Index
Sets the Index number of the Conveyor to a value other than the default value.
Example:
Set Conveyor1.Index = 5
Length
Changes the length of the Conveyor. The length will be in Distance Units (see Tools menu, Preferences, Distance option). This replaces any length parameter that has been set in the Conveyor Dialog.
Example:
Set Conveyor1.Length = 25: changes the length of the Conveyor to 25 units.
Load Space
Used with the Transport Plug-In to amend the side of Conveyor space allocated to loading items.
Example:
Set Conveyor1.Load Space = 5: sets the Load Space to 5 units
Name
Allows the name of the Conveyor to be changed or accessed.
Example:
Set Conveyor1.Name = "Change the Name": changes the name to whatever is inside the inverted commas
Set Var1 = Conveyor1.Name: sets a text Global Data Item to contain the name of the Conveyor
Results Collection Mode
Allows control over the collection of results for specific object through Visual Logic.
1 = Results Collection on 0 = Results Collection off
Example:
Set Conveyor 1.Results Collection Mode = 1
Selected
Sets whether the loader is selected onscreen or not.
1 = Selected
0 = Not selected
 Set Conveyor1.Selected = 0
Speed
Sets the Speed that the Conveyor runs at to a value. This replaces any speed parameter that has been set in the Conveyor Dialog.
Example:
Set Conveyor1.Speed = 10
Read Only Properties
Count Contents
Returns the number of Work Items currently located on the Conveyor.
Example:
Set Var1 = Conveyor1.Count Contents
In Count
Returns the number of incoming routes to the Conveyor.
Example:
Set Var1 = Conveyor1.In Count: Sets Var1 to the number routes that are connected to the Conveyor
Out Count Returns the number of Outgoing routes from the Conveyor.
Example:
Set Var1 = Conveyor1.Out Count: Sets Var1 to the number routes that are connected from the Conveyor
Ready Time
Returns the number of time units from now that an item is likely to reach the head of the Conveyor (“likely” because numerous things that could alter this value may occur; breakdowns, blockages etc.).
Example:
Set Var1 = Conveyor1.Ready Time
State
  • 0: Waiting
  • 1: Working
  • 2: Blocked
  • 3: Change Over
  • 4: Stopped
  • 5: Off Shift
The State property returns the current working state of the Conveyor
Example:
Set Var1 = Conveyor1.State
Unique ID
