Set Travel Time
Sets travel time between two objects.
  • Leaving Work Center - The source simulation object
  • Time - The travel time to the destination
  • Destination - The destination simulation object
You can find a simulation example on the use of this command here, where each item's Travel time depends on a Label:Set_Travel_Times_using_Labels.s8
