Set Object Visual Scaling
Set the auto scaling and scale size parameters for some types of object
  • Object - The object that has scale as one of its display parameters. Text “ALL” will repeat across all objects.
  • AutoScale - Is autoscaling on? (0 or 1) (or -1, see next parameter) (2=Only set if autoscale already on)
  • Current Scale Maximum - The maximum value displayed in the chart or other display (or initial maximum if autoscaling is on). If this is a global data item then -1 in AutoScale parameter will return current value)
