Get from Database Field
Looks up a nominated field in a database, and write the value returned to a Global Data Item. The SQL Database must be already referenced through the SQL Database Queries field (see Object menu). Each iteration returns the next value in the database.
- Simul8 Global Data Item: Variable to receive the data from the database
- Simul8 SQL database: Name of the database to retrieve data from
- Field: Field to query
