Troubleshooting When Using Machine Learning
Sometimes when using Machine Learning, you may get an error. If this happens, Simul8 will return a 5-digit error code to help diagnose its cause. For help rectifying the error, look up the code in the table below.
Please also ensure that you are using the 32-bit version of R and Python.
Code
Error
Solution
10001 or 10002
Could not read in Command line arguments
Save your work and restart Simul8
10003
Failed to import algorithm file
Make sure the file you are trying to use exists and try again
20000 - 29999
Failed to access Simulation parameters
30000 - 39999
Failed to read in Simulation parameters
40000Failed to return a valueCheck that all the relevant R/Python packages are installed and that there are no errors in your R/Python script.
50000 - 59999
Failed to return value from algorithm file
Make sure the function you are trying to use returns a whole number (for routing) or a real number i.e. not an imaginary number (for distributions)
If any problems persist, please contact support@simul8.com confirming the error code you have been given.
