Command Dialog Box
The Command Dialog Box allows you to edit or create a Visual Logic command.
The Command Dialog Boxes are specific to the command. Most have parameters that you need to fill in. For example, the command “Set Object Distribution Parameters” requires the following parameters to be entered:
- Object
- Distribution to be Changed
- Distribution Type
- Parameter 1
- Parameter 2
- Parameter 3
- Parameter 4
Once all of the required parameters have been entered and the OK button has been clicked the following will appear in the Visual Logic Section Window:
Set Object Distribution Parameters Work Center 1 , Operation Time , Normal , 10 , 2.5 , 0 , 0
