Do Not Display Dialog
Use in the On Open Visual Logic section of a dialog so that the dialog is not displayed to the user.
You could use this to open a spreadsheet from a command menu without having to make the user click through a dialog first. Or you could use it with the Run Exe command when you wish to display your own application for data entry for example but don't want to send the user through another screen to do this.
You must have Simul8 Professional for this command to work and must have the VL can hide dialogs option checked.
