Embedding a Simulation
You can embed an uploaded simulation to your own site. Once you have uploaded a simulation, access the sharing preferences for the simulation you wish to share.
Access the Share Settings of the Simulation
You can share the simulation after it has been uploaded and published. Each simulation has its own sharing settings, so you can share simulations on a case-by-case basis.
- Access your simulations either via the Simul8 Studio homepage, or via My Simulations
- Select the Share icon at the bottom right of a simulation’s thumbnail
This will launch the share interface for the selected simulation
Generate an Embed Code
Once in the share interface for a simulation, you now have the option to generate an embed code to display the simulation on your own website.
- Select the Embed Tab
- Click the green Embed button to generate an embed code for the simulation
Using the Embed Code
After selecting the Embed button, the page will automatically refresh and present you with an embed code to use on your own website.
- The embed code which can be copied
- Use the Delete Embed button to stop access of an embedded simulation
- Change the size of the simulation window when embedded. Choosing an option from this dropdown will update the embed code
